comparison my k1200 to my 2006 vfr
Discussion in 'General VFR Discussions' started by adamjenkins, Mar 7, 2015.
  1. adamjenkins
    adamjenkins New Member
    Massachusetts
    So today I took out my new purchase 2006 vfr 800. It seems rough almost feels like a miss..idles fine...my k12 00 is so much smoother...Is it just the v4 way to be rougher than an in line 4? Wondering if it needs a tune up..tks
  2. John451
    John451 Member
    Hard to say without knowing what your rough is ?
    I do know from riding a friends K1300S back to back with my Gen5 its IL4 feels initially smoother but found over distance the slight tingle it had was incremently more annoying, where as I like the VFRs v4 type of vibration regardless how long I ride.
  3. Allyance
    Allyance Member
    Germany
    East Bay, California
    6th gens run a little rough under 3K rpm until you get a PowerCommander. The V4's never sound like a hot I4, but they pull like crazy. Whole different firing order and balance. I had Vance and Hines pipes on my 83 and it always sounded different.
  4. Alaskan
    Alaskan Member
    Alaska
    Rough?
    My VFR is the smoothest motorcycle I have ever ridden.
    VMMV.
  5. John451
    John451 Member
  6. PawnBoy
    PawnBoy New Member
    Waterloo, ON
    My 2002 is certainly not rough. It doesn't have the same continuous exhaust note that your standard inline 4 has, but every I4 I've tried has had some buzzing or vibration at certain RPMs. Like Alaskan said, my VFR is the smoothest motorcycle I've ever ridden.
