conversion to 520
Discussion in 'General VFR Discussions' started by Motomaj, Dec 16, 2006.
  1. Motomaj
    Motomaj New Member
    utah
    hey i'm sort of new to the vfr scene..at least on the web soooo...i don't know what the advantage would be to convert a 530 sprocket set/chain to a 520. help me to understand please. i need sprockets and a chain... thanks the Maj
  2. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    Hi motomaj. The conversion to 520 saves you a little bit of weight but not a lot and its probably also a litle less expensive thatn 530 pitch equipment. I did the Vortex 520 conversion, a vortex front/rear sprocket set with an RK X-ring chain. I noticed a little difference in the feel of how the bike accellerated. It seemed to have a little less drag, but then that could be because my chain and sprockets needed replacing. I also gained alittle in the accelleration dept because I went up 2 teeth, 43 to 45, on the rear.
  3. RVFR
    ^yep what he said But for me I stayed 530 with stock gearing as in 16-43 it felt right to me. Price could be a bit better going 520. especially if you go buying a set of sprockets and chain combo I know it's a better price. other wise unless your racing, not much can be felt, I've done it both ways and haven't notice anything that jumps out at me. Like V-man was saying either drop a tooth on the counter shaft or up on the rear will give you more snap. Ha but at a top speed cost, lol ya I know who goes there? other thing with a gear ratio change comes the Speed-O well be off. other than that, it's your call sorry to say.
