Coolant capacity
Discussion in '6th Generation 2002-2013' started by RobVG, Nov 9, 2023.
  1. RobVG
    RobVG Member
    White Rock BC
    '06
    You "might" have read yesterday in the Mechanics Garage that I was having trouble bleeding the air after a coolant change.
    Now I think I better check my reading comprehension. The FSM says the radiators and engine take almost 3 liters. Separately is says the reservoir takes almost 1 liter. So that means the whole system takes 4 liters, right?
    I've got 1 in the res and only 2 down the filler neck. Doesn't want to take more.
  2. bmart
    bmart Insider
    Charlotte, NC
    It gets filled until it is full after burping the system. The amount is irrelevant, as people drain them differently (hose, pump bolt, cylinder drains, side/center stand, etc.
    RobVG likes this.
