Coolant check
Discussion in '8th Generation 2014-Present' started by Great Guy, Oct 11, 2019.
  1. Great Guy
    Great Guy New Member
    How do you do this on a 2019 VFR800F? I have tried shining a torch through the pastic gap, but this does not help. Is one supposed to unscrew the the blach plasic thingy? Thanks
  2. Thumbs
    Thumbs Member
    Bath(ish)
    Take the seat off
  3. Great Guy
    Cheers
  4. philois1984
    philois1984 New Member
    Queensland, Australia
    If you shine a torch from underneath in the shade or at night you can see the level. I check mine in the garage before a ride. As already stated taking the seat off is probably the most accurate way. Recently had a hole in my radiator repaired and after riding 1000km discovered the coolant level was at the halfway point on reaching my destination discovered the tank was empty!! Thinking I still had a leak I had it checked again, no leak was found. Topped up the tank and now some 3000km later it hasn’t moved. Although I am aware it is common to have air in the system after a coolant change I didn’t think it would be this much or take that long to clear. I now have a radiator guard fitted.
  5. Great Guy
    Cheers
