coolant in tank is blue, but under pressure cap is green - is something wrong?
Discussion in 'Mechanics Garage' started by viffviff, May 30, 2014.
  1. viffviff
    viffviff New Member
    Sweden
    Peterborough
    I've not had the bike long and noticed the coolant in the expansion tank was a little low. Took off the fairings to refill it, and noticed that the coolant in the expansion tank is a blue colour, but when I take the pressure cap off (on the RH side) it is full of a bright green liquid. Is something blocked / wrong, or can this be normal? Could the thermostat be stuck shut or there be a blockage somewhere? Any advice appreciated.
  2. Mark919
    Mark919 New Member
    Detroit Suburbs
    Standard Honda coolant is blue. A number of aftermarket coolants are green. Possibly someone serviced the bike recently and replaced the coolant in the overflow tank with correct Honda coolant. It might take a while before complete mixing of the fluids takes place.
    If the fluid was up to the top under the pressure cap I wouldn't be concerned. I would want to know who changed the fluid last and I'd want to know what they used. Maybe then I'd flush the system to be sure.
