crankshaft pulse generator
Discussion in '1st & 2nd Generation 1983-1989' started by fatso1277, Feb 8, 2013.
  1. fatso1277
    fatso1277 New Member
    South Suburb IL.
    Okay i was looking over my crankshaft pulse generator on the 87 700. i gotta question on a connection. i have the 6 pin coupler. and then i have a coupler that you connect it to something, but i dont know where. it looks like it you could slide something into it. but i dont know where it has to go. and help..
    after looking at service manual, it looks like the connection for a thermo sensor. so i assume its a switch of some sort.
    maybe oil pressure or neutral switch?? where do i connect it.
    oil pressure sensor wire has a round eye-type connector for a single screw.
  3. fatso1277
    South Suburb IL.
    no this connector is not for a screw...its looks like you push something into it. like a switch..i assume its the neutral switch.
  4. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    Starter diode?
  5. fatso1277
    South Suburb IL.
    This is from a 94-97 vfr but i circled the part i'm confused about. i need to know where it goes.
  6. fatso1277
    South Suburb IL.
    okay guys i figured it out...thanks for the help...woohoo.
