Delayed reaction when turning throttle.
Discussion in 'Mechanics Garage' started by anarchy13, Mar 4, 2011.
  1. anarchy13
    anarchy13 New Member
    Germany
    Hey peeps. Picked up a 84 VF750 Sabre that wouldnt fire up. Cleaned and rebuilt the carb and she fires up like a champ now. Just when i give it gas she only revs up real slowly and backfires alot and when i release the throttle takes while to return to idle. I checked out the cables and the grips and the carb assembly spring. All of thats fine so everythings returning properly. Can it be Fuel/air mixture setting? timing advance setting? air leak that i cant find cause i tried the spray trick? or what else is there????? Id really like to ride my bike soon :smile:
    Since it's electronic and built into the CDI, spark timing seldom or never gets out of whack, but you should check (with airbox off so you can see) that all 4 vaccum slides move up and down the same amount and at the same time. They can get sticky. Maybe a bad diaphram ??
  3. tinkerinWstuff
    agreed with squirrel. good spot to start - visual inspection of vacuum slider operation. Lots of possible what-if's, best to start with basic troubleshooting.
  4. anarchy13
    Germany
    Oh ya about the vacuum slides can i check em without pulling em out???
  5. anarchy13
    Germany
    So i can visually check em without opening the tops of each carb and pulling em all the way out??? That would be nice cause im getting tired of pulling carb assembly out and putting it back in altho i am starting to get real good at it ;)
  6. Keager
    Keager Member
    something else I just thought of as well. Could be the grease inside the cable itself has worn out if it was sitting outside.
  7. tinkerinWstuff
    yes. The idea is to take off the airbox. Connect a temporary fuel can. Keep a fire extinguisher nearby for any temporary fuel can accidents. Run the bike. Watch the behavior of the vacuum sliders as you rev up the engine.
    Need to know if all four are acting the same or if one is not opening. Maybe take a video if you can. Good chance that one is not opening for one reason or another. This test will help prove if your problem is carburation related and which carb or cylinder may be your problem.
    throttle cable issues don't sound as likely because you said it's slow to rev AND slow to return to idle. A throttle cable issue is more likely to be related to slow return to idle because spring pressure is what returns the plates to the closed position - unless the operator physically twists the grip back to closed.
  8. betarace
    betarace New Member
    Middleburg, VA
    +1 vacuum leak somewhere, check boots for good seal by spraying a little carb cleaner around each boot while running. if the RPMS increase, you have found your leak
  9. tinkerinWstuff
    problem you have to watch for though is that when you spray the carb cleaner down around the boots, especially the front ones, the airbox pickup is right there. It sucks up the carb cleaner fumes and you'll notice a change in RPM - but you don't know if it's the boots or the intake. Make sure the airbox cover is off and you're using the temporary fuel can when doing testing with carb cleaner.
  10. squirrelman
    Didn't he claim he tried that ??
    It's all done with the engine running, so, no, you don't pull them out.
  11. anarchy13
    Germany
    No i aint checked the slides while running. I rebuilt the carb finally got the bike to start. It aint the cables i lubed all that pretty good and everythings returning to normal. I gottta make me one of those little test gas tanks yall r talking abot. I did order a new petcock cause mine was defect its letting fuel flow even without a vacuuum. This is what i have lined up for this week an next. Adjusting valve clearance, synchronizing carb, changing out petcock. Plugs are new but im gonna double check gaps. Got the iranium type plugs they cost a arm and a leg hope theyre worth the money anyone know? And im gonna look through the airbox and see what i see moving and try to even film it :) hey when making a little test gas can, i can use a regular plastic drink bottle? Gas wont eat through it????? Just doublecheckin :)
  12. anarchy13
    Germany
    Hey Squirrel how goes it? i took some vid and they workin right? All 4 are doin the same. YouTube - 84 VF750S vacuum slides in Action!!!!
  13. anarchy13
    Germany
    Cool thanks for the tip!!! heres a short clip of what my vacuum slides look like in action altho i could only film the one!!!
  14. betarace
    betarace New Member
    Middleburg, VA
    you rock dude
  15. anarchy13
    Germany
    Here ya go Brother 2 vids of just the Engine running. IS SHE SOUNDIN ALRIGHT FOR A SABRE OR DO YOU HEAR SOMETHING BAD????? :flame:
    YouTube - 84 VF750S Motor Sound1
    YouTube - 84 VF750S Motor Sound2
  16. tinkerinWstuff
    Hard to be sure from an amateur youtube video, but it doesn't sound smooth like a V4 should. Sounds like it's loping a bit and there might be a tick or knock in there?
    dead cylinder?
    carbs not synchronized properly?
    valves gapped properly?
    Sounds more like a V-twin than a V4
  17. tinkerinWstuff
    If all four where behaving the same as shown in the video, then it looks like normal operation. All four should look like they are opening and closing at the same time.
    It doesn't look to me like the thing is slow to rev up or return to idle. But it doesn't sound like it's running as smooth as it could be. I don't recall if you vacuum balanced (synchronized) the carbs?
  18. anarchy13
    Germany
    I cant see all 4 vacuum sliders at the same time cause the frames and components are in the way. But no sir i havent synced yet. I finally saved the money for a 4 carb sync gauge and it should be in by this weekend so we will
    Sync her and then ill definately tell you if i notice a difference or not.
  19. anarchy13
    Germany
    I also have a compression gauge so i can get all cylinders checked out before the end of the weekend also :) will be in touch :)
  20. anarchy13
    Germany
    As far as the valves go i ordered a couple feeler gauges from the States and i didnt know that .12 was a special size not included on just any feeler gauge so now i ordered the ones i got for nothing and have to re-order. Will take awhile till i can gap the valves!!!!!
