Design a new VFR - Suspension
Discussion in 'Anything Goes' started by Hopsterman, Nov 7, 2006.
What type of suspension - cheapest to most expensive
Poll closed Nov 21, 2006.
  1. No Adjustment
    0 vote(s)
    0.0%
  2. Adjustable rebound and spring preload
    1 vote(s)
    3.8%
  3. Fully adjustable(comp,rebound & preload) Front & Rear
    9 vote(s)
    34.6%
  4. Fully adjustable Front & Rear , plus upside down forks
    16 vote(s)
    61.5%
  1. Hopsterman
    Hopsterman New Member
    Rutherford NSW
    What type of suspension would you like
    Cheapest to most expensive option.
  2. KC-10 FE
    KC-10 FE New Member
    It can't be that pricey since the CBR600RR costs substantially less and it has fully adjustable everything.
    KC-10 FE out...
    :plane:
  3. reg71
    I agree with KC-10 on this one. They already have the components. It seems to me it would be cheaper just to use the same stuff.
  4. RVFR
    How bout something thats like on the other Honda sportbikes, ya know something with adjustability please
  5. Rev
    Rev New Member
    Olympia,WA
    I'll take a fully-adjustable rear shock and usd front forks with 320mm disk brakes, radial calipers and master cylinder, and SS brake lines, please.
  6. Hopsterman
    Rutherford NSW
    Inline 4s are easier to make. But suspension, I agree, shouldnt be much more expensive. Compression dampening is simply another couple of holes and a couple of small valves.
    Upside down forks, are the same, but upside down. They shouldnt be any dearer.
  7. grinder
    grinder New Member
    British Columbia, Canada
    Except the 600RR is substantially lighter and doesn't typically carry a lot of junk. Heavier means it needs to be stronger. I suspect just using the 600RR suspension on a VRF would potentially get you in serious trouble. They go to a lot of trouble on the RR's to keep weight down so I think there is probably little room to play with in terms of strength. The VFR would probably need a specific suspension design.
    Having said all that I still think that at the price of a VFR they should come with fully adjustable upside down forks and a decent rear shock. In my opinion that is the biggest weakness of the VFR.
  8. Mainjet
    Mainjet New Member
    Southern Ca.
    The 600s USD fork design is much stronger, it would only need heavier springs, proper length, & offset to match the new VFR. Hopefully Honda will give us fully adjustable suspension, with USD on the 7th.
