Hey gang- I'm trying to do some electro-work on my 85 VF500F Interceptor and need some advice. I'm trying to wire up a hazard light switch. I've heard of this before, but can't seem to find the link. What I want to do is something super simple. No relay, no flasher diodes. Just a simple switch with 2 prongs and a couple feet of wire. One wire goes from one tab/prong on the switch to one front signal, one wire goes from the other tab/prong on the switch to the other front signal. When you need hazard lights/all four, you simply flip your signal switch to EITHER left or right, then flip the switch, and BINGO, all four flash. Except I can't remember which wire coming from the signals I hook to the switch...the positive one (the one that flashes when the turn signal is on?) or a negative/ground? Any of you guys done this and can offer some insight?
