DIY mirror turn signals
Discussion in 'Mechanics Garage' started by gwcrim, Dec 11, 2011.
  1. gwcrim
    gwcrim New Member
    East Coast of Ohio
  2. safetypro10
    safetypro10 New Member
    Dallas, TX
    Are you aware of the project over at VFRD about GSXR and CBR1000RR mirrors with turn signals being adapted to VFR's? All you need is an adapter.
    Just one of many possible ways to do it. I used Honda Blackbird mirrors myself.
    [​IMG][/IMG]
    Larry
    VFRrider
  3. Rainbow7
    Rainbow7 New Member
    Muslim-free Queensland
    Those Blackbird mirrors make the bike look like Obama.
  4. safetypro10
    Dallas, TX
    That's Prez VFR to you. Yes, kinda dumbo ears, but I can see behind me.
    Larry
  5. gwcrim
    gwcrim New Member
    East Coast of Ohio
    I've read some threads about the other mirrors. Don't they all require a spacer or adapter of sort?
  6. safetypro10
    Dallas, TX
    Adapter. One of the guys over at VFRD makes them. Bolt on all the way.
    One alternative.
    Larry
  7. gwcrim
    gwcrim New Member
    East Coast of Ohio
    Those adapters are now made of unobtanium. Any other ideas?
  8. Davis5g
    Davis5g New Member
    Pittsburgh, PA
    Someone on here drilled holes and mounted amber LED's in his mirrors and filled the holes with clear epoxy, I can't seem to find the thread though.
  9. safetypro10
    Dallas, TX
    Again, over at VFRD, someone used clear plastic to make their spacers, with turn signals built in. Personally, those black spacers you see in my pic are Delryn, a tough plastic that sands and cuts well, can be buffed and painted. I formed them to fit my fairing mounts and holes and bolted the mirrors to them and the fairing.
    Your bike, your choice. I THOUGHT about modding some BMW R1100S mirrors I have, but can't bring myslef to cut up the mirror cups.
    Maybe some thick aluminum for the fairing and drilled to accept the new mirrors with signals built in would work.
    Just a few ideas.
    Larry
  10. 34468 Randy
    I remember seeing something like that too. But what I remember is someone pouring a clear epoxy into a mould fitted with the amber L.E.D. lights and this mould became the spacer between the mirror's base and the faring. Acted like an extension with the added signal lights. I really liked that idea. If I ever feel industrious, I think I will try that one for mine but not likely this year.
  11. BWeiss
    BWeiss Johnny Partseed
    Rancho Cordova, Ca
    I put the gixxer mirrors on mine. Made my own mounting adapters with scrap plastic from a local plastic shop. Turned out ok, even though I fucked them up because i was under time constraints for an upcoming ride. I'll be remaking them once I have my new garage set up.
  12. tinkerinWstuff
  13. DaHose
    DaHose New Member
    Napa, CA.
    Hey, Tink. Can you put up a pic of those just mounted straight onto the stock fairing location? I want to use the same ones, but would like to see just how different the base is, compared to stock.
    Jose
  14. gwcrim
    gwcrim New Member
    East Coast of Ohio
  15. BWeiss
    Rancho Cordova, Ca
  16. gwcrim
    gwcrim New Member
    East Coast of Ohio
    Are those mirrors as long as the stockers?
  17. tinkerinWstuff
    quality appears to be good, especially for the price. Looks like they are about the same length as stock. I don't have any OEM 5th gen mirrors to compare to but could measure against my 3rd gen stock mirrors. I think they are the same.
    I'll try to remember to get a pic of them against the fairing. I need to tweak my fairing stay anyway so it's no extra work. Just give me a day or two please.
  18. Spike
    Spike New Member
    Thurn also sells VFR compatible mirrors with built in signals.
    Or if you want to go the add on route, Kissan sells add on mirror blinkers
  19. gwcrim
    gwcrim New Member
    East Coast of Ohio
    That's super. How does one order Thurn parts?
  20. gwcrim
    gwcrim New Member
    East Coast of Ohio
