DIY tail tidy or fender eliminator.
Discussion in '8th Generation 2014-Present' started by Whiplash316, Jun 9, 2019.
  1. Whiplash316
    Whiplash316 New Member
    Out of desperation to get rid of the huge mud flap that came on my 2014 VFR800, I made my own tail tidy out of parts that came off of the stock rear fender. Hopefully the pictures explain everything well enough that others can follow along if they are looking to do something similar. I didn’t think of making a tutorial until I was already almost finished with it. I cut the plastic mud flap part where it bolts onto the tail in order to use it to fill the space and to strengthen the attachment point. Sanded and drilled a couple of holes in it. Then took two brackets off of it. One of them I drilled two holes into and the other I cut tabs off of and grinded and sanded the lower portion off of. Both brackets were then stripped of the factory paint and then painted in a semi gloss spray paint. Stainless steel bolts were used along with some factory bolts to attach it. It sits perfectly under the factory license plate light and is much higher than stock. It almost looks factory and I’ve only got the cost of a can of spray paint into it plus my time. I hadn’t seen anyone do this yet, so figured I’d share since there aren’t many options.
  2. Petrohead
    Petrohead New Member
    Nicely done, looks great! I may have to copy....
    Bubba Utah and Whiplash316 like this.
  3. mello dude
    Romania
    Creativity at its finest.
    Whiplash316 likes this.
  4. Petrohead
    Thanks for posting @Whiplash316. It was a rainy Saturday so I copied the post. Pictures and text provided ample information to get it done. Well thought out use of existing factory parts.
  5. Whiplash316
    Looks good man! Glad you were able to follow along.
  6. Vulcanator
    Vulcanator New Member
    Portland, OR
    Is it possible to keep the side reflectors with this modification? Looks like you've done a great job.
  7. Whiplash316
    Sure is! I just decided to cut them off. That’s one less step you have to do. Thanks for the kind words!
  8. Bubba Utah
    Bubba Utah Member
    Utah
    How much to make another set for me? ;-)
