Does your VFR make a sound when you engage the clutch in neutral?
Discussion in '6th Generation 2002-2013' started by short it, Nov 23, 2013.
Tags:
  1. short it
    short it New Member
    Hello.
    I test drove a 2006 vfr800 yesterday and am considering purchasing it. I noticed that when the clutch was engaged while the bike was in neutral (engine running), there was a whirring sound. It went away when the clutch was let back out. Is this a normal sound?
    The bike only had 4300 miles on it.
    thanks for any insight.
  2. Scubalong
    The fluid might need to be flush.
    When the oil and the clutch fluid is old it will cause the clutch to engage prematurelly. I found new fluid fix the issue on my bike :wink:
    Damn that bike is brand new :rolleyes:
    :welcome: to the madness :wave: good luck with the purchase. Any other question feel free to ask.
  3. truewheel
    truewheel New Member
    Yep my '06 does exactly the same thing. Only noticed it last week. I bought mine a couple of months ago. I have 30,000kms on the clock, which is a bit over 18,500 miles.
    I dunno if it's normal or we share the same issue however.
  4. reverus
    reverus New Member
    Albuquerque, New Mexico, United States
    just the clutch plates rattling about. pretty normal. as mentioned fresh oil quiets it down a bit.
    you should hear the clutch in my supra, twin plate with an aluminum flywheel, sounds like insane rod knock untill you go lol
  5. VFR777
    VFR777 New Member
    Kansas
    Mine is just the opposite...mine rattles in neutral after you let the clutch out.
  6. short it
    short it New Member
    SOrry. That's what I mean. When the transmission is in neutral and I squeeze the clutch lever, all is quiet. But when I let the lever out, I get a rattle. Apparently it's normal….
  7. TOE CUTTER
    Lots of parts spinning aboot when you let the clutch oot, gonna make a little noise.
  8. VFR Love
    VFR Love New Member
    New York
    I have the same "problem". Best to keep it in gear and never stop:)
  9. Gweglez
    Gweglez New Member
    Southampton, United Kingdom
    My a2 does it aswell. Nothing to worry about
  10. Bandit
    Bandit New Member
    Sydney, Australia
    Yep, same noise with my 2010 model. You notice it at first, then you tend to get used to it. Nothing to worry about.
  11. tinkerinWstuff
    My 3rd gen did exactly that until I synced carbs. Once I did a good sync, all was quiet.
    May need a starter valve sync - equivalent to a carb sync on fuel injected models.
  12. squirrelman
    ^^ Zackly right ! Proper carb or FI throttleplate synch keeps things spinning smoother at idle and just-above so clutch plates don't jiggle about causing noise and vibration as others said.:sneakiness:
    What does your blessed manual specify regarding miliage-based synch re-checks and adjustment ?
