Dunlop tire is 3 oz unbalanced
Discussion in 'Mechanics Garage' started by sunofwolf, May 21, 2015.
  1. sunofwolf
    sunofwolf New Member
    something is really wrong here-I doubt I will ever get a Dunlop tire again
  2. RotaryRocketeer
    RotaryRocketeer New Member
    OKC Metro, OK
    (Insert joke about falling over here)
  3. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    Next time try rotating the tire on the rim to a few different positions as you might be able to offset some of the weight difference by putting the heavy side of the wheel directly across from the heavy side of the tire.
  4. sunofwolf
    its not 3oz out-the weights are a couple grams, maybe 1/4 oz, I am use to car weights. But still more than most tires, I guess there is nothing wrong here, just me:unsure:
  5. OOTV
    OOTV Member
    Like I mentioned in your other thread, I had 7 (1/4 oz.) weights on a wheel once. Although it looked like a lot of weight, that's only 1.75 oz.
  6. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    And there's no guarantee that it's the tire. The rim itself could be that far off. Most of the rims I've changed tires on are not well balanced. Which, oddly enough, seems to fit this thread very well. :eek-new:
  7. sunofwolf
    Dunlop called me-maybe I can get a big discount from them- I don't see how the rim is giving me problems as this is the third set of tires only. There is nothing wrong but one of the weights was loose-I used a little red Loctite to fix that-ran out of super glue,. I guess with me working on it -never be perfect but I don't care anymore.:spider:
  8. Lint
    Lint Member
    Simi Valley, Ca.
    I think you should get it rebalanced properly. Maybe pay for it to be professionally done.
  9. Gator
    Gator Member
    You could always take a power sander to the heavy side of the tire.
  10. sunofwolf
    no the weights do that-I need all the rubber on the tire. Sometimes I may think too hard, am
    happy that I don't drop the bike any more, everything else is just wear and tear. Getting better not worse, so it don't matter any more:drum::party2:
  11. 34468 Randy
    Smoke a fat doobie and try ballancing again use gorilla tape for loose weights and weights from Freightliner may work better.
  12. sunofwolf
    the tire will wear out no matter what I do-next time I get a pr4-problem solved.:bandito:
  13. Badbilly
    The oot of balance factor may be more toward SOW than a tire or wheel.
  14. sunofwolf
    Yes I was out of balance as a tire change done right is not that simple, a little red Loctite on the wheel weight fix its wiggle. Dunlop rear tires might not be perfectly balanced-the red dot means little on this back tire.:scooter: I guess, I worry too much because of Randy haunting me with his drop threads.
  15. robles
    robles New Member
    This seems like an interesting thread. has been bookmark
  16. sunofwolf
    Anything Goes wrong-either Randy or BB did it. "Quote from Obama".:chairshot:
  17. Badbilly
    That red dot can be several things, check your forehead.
  18. jorgescar69
    jorgescar69 New Member
    La Puente, CA, United States
    DynaBeads.... I love them
  19. 34468 Randy
    I've heard, from a source of unknown reliability, that they stopped making dynaBeads so we are left with buying what may be left out there. Have you heard anything of the such?
  20. sunofwolf
    why not just put some ping pom balls in there, how do you know they actually do anything?
