Easy way to check if Flapper is working?
Discussion in '6th Generation 2002-2013' started by signal, Mar 23, 2020.
  1. signal
    I am looking for an easy way to test if my Flapper is working. You can't just put it in neutral, as neutral kills the circuit that actuates the flapper. I suppose I could put it on center stand in gear and rev it, not sure how safe that would be (actually i have never done that....anyone?). I just want to see it actuate to know that it is working proper. Any ideas?
  2. 34468 Randy
    You should be fine putting the bike on the center stand to check it out. I lube my chain that way all the time and run the bike through the gears that way. I think there is sufficient weight over the front wheel to keep the rear up in the air. If you are worried about that, Place some weight over the front wheel.
