Electrical issues
Discussion in 'Mechanics Garage' started by Barto169, Aug 13, 2014.
  1. Barto169
    Barto169 New Member
    Natrona Heights PA
    I have a 1994 Honda VFR 750 and just replaced the Battery, Stator, and voltage regulator. The bike still needs jumped, cause the battery just gets drained after I jump it and run the bike. I bring it home and the lights just go dim and will not start??? Am I missing something or do i need something to get my bike running again? This is my first bike and it was running great till all this happened.
  2. thx1138
    thx1138 New Member
    Perth
    Check the earth points maybe?
  3. Quattro73
    Quattro73 New Member
    Norway
    Norway
    Agree, and check your charging voltage too.
  4. Allyance
    Allyance Member
    Germany
    East Bay, California
    Check your connectors to & from R/R. Corrosion can limit amount of current, but still show voltage. Do you have a meter? Check voltage at battery when running, should be aprox 14+ volts.
    Easy method for cleaning contacts:
    use small emery board (finger nails), peel off course sandpaper on one side and trim to fit in connectors
