electrical problem 84 VF700, HELP
Discussion in '1st & 2nd Generation 1983-1989' started by 84VFR, Mar 23, 2012.
  1. 84VFR
    84VFR New Member
    Anyone ever had this: I was riding my 84 VF700F interceptor, and I went to use the turn signals, and nothing worked. The horn was also out, so I went home and replaced the fuse. When I did every light on the bike blinked, except the blinkers. Headlights, neutral light, everything. The only thing I had done was earlier that day I sprayed some lithium grease on the starter switch because it sticks. eventually the blinker relay burned out, I assume because it was getting too much power. I ordered a new one, but in the meantime I rigged some wires and bayonet plugs onto an automotive relay. The issue still exists. The other lights don't go out, they just dim a bit and go back to bright.
    I have looked at the wiring diagram, and can't find anything that makes sense. If there is a short, it would have to be someplace where there is power for everything, and it routes through the blinker relay. Unless it is a negative wire shorting, because every electrical thing is grounded.
    Anyone know where I should start?
    When I stared the ride, everything worked normal.
    Scott
  2. FoothillRyder
    FoothillRyder New Member
    Sierra Foothills
    Sounds like a grounding problem to me. I would methodically go through every ground connection on the bike (starting with the battery), take them apart, clean the terminals, and put 'em back together.
