End can to headers gasket?=Loose can!
Discussion in 'Mechanics Garage' started by rccaulfield, Nov 20, 2009.
  1. rccaulfield
    rccaulfield New Member
    My end can is very loose and theres lots of space between where it joins on to the collector box! So checked out a honda microfiche and i need a gasket for here, which i now have- is there a procedure to fitting??? Damn thing wont stay in place when slipping can on and either falls in or gets squashed!
  2. TOE CUTTER
    Got a pic? It may help.
  3. rccaulfield
    To wrap this up- place circular gasket inside of end can. Its a real tight fit so remove clamp and space out the gaps with a flatblade screwdriver and push in at the same time!
    Once in refit clamp and push end can onto the headers(another tight fit!!!) Tighten everything up and shes brand new again!!
