Engine coolant temp
Discussion in '6th Generation 2002-2013' started by highway star, Oct 17, 2019.
  1. highway star
    highway star New Member
    North Mississippi
    Cruising temps are 175-185F. At stop light temps are low 220'sF.
    '09 with 25kmi. I change the coolant every year. Fan works.
    OEM tstat. Seems like a wide range in temps?
  2. Diving Pete
    Perfectly normal - Almost identical temps to my 08.. Try not to stop too often - it gets too hot. lol
    jstehman likes this.
  3. Terry Smith
    When you are cruising with good airflow, the engine temp is dictated by the opening temp of the thermostat, which is right around 76-78C. When you stop there is no airflow theough the rads so the temp increases to the point where the thermoswitch kick the radiator on, usually right around 100-102C. Temps should then sit around or a little above that point unless it is REALLY hot where you are.
  4. xpcgamer
    xpcgamer New Member
    My fans kick in at 220 and temps drop very quickly. Sounds normal to me.
