Engine noise VFR 800 FIX 1999
Discussion in 'Mechanics Garage' started by Geir Bull, Apr 8, 2012.
  1. Geir Bull
    Geir Bull New Member
    Hello, I has tryed to have the first valve adjustment fter 90000 km. There where 2 valves that needed adjustment. One exhaust vlve was
    0,4 and should be 0,3. After new shims ws mounted, I measured OK clearansees,å so all seem good!
    The start went well and ll seemped good until I trhottled the engine. From
    2000 rpm there startet a noisy loud, that i cant understand. The loud sounds like wrong valve clearanse, which incrases dramaticly with the rpm. I did not trhottle more than 4000 rpm.
    I used the Haynes manual Regarding that you should not rotate the engine unter-ckockwise.I did try that, could it harm the engine?
    I hope someone has an explanation for my VFR problem!
    Geir Bull
  2. kennybobby
    kennybobby New Member
    It would seem that something was done during the valve adjustment that is causing a noise to appear that was not present before the adjustment.
    Re-check the valve clearances but do not rotate the engine counter-clockwise.
  3. squirrelman
    Check the cam timing also !~
  4. kennybobby
    i talked to a vf1000r buddy of mine today and he thinks that counter-clockwise could cause engine damage due to the slack/ backlash of the cam chain allowing a piston to hit a valve. i have no way to verify this information, it is only offered as an aspect to consider when troubleshooting...
  5. tireguyfromMA
    tireguyfromMA New Member
    Gloucester, MA
    The cams in the 1999 VFR are gear driven, there is no cam chain.
  6. TOE CUTTER
    Best to check everything you touched. I have these butt puckering moments from time to time and it is most often the smallest thing you overlooked. My last was a fucking disaster and a simple mistake.......oh so simple. It will happen if you wrench.....mistakes are made by the best of us.
  7. TOE CUTTER
    Was a tractor engine not a motorcycle engine I ..........modified......just for the record.
