engine removal help
Discussion in '3rd & 4th Generation 1990-1997' started by dinenoj, Dec 26, 2009.
  1. dinenoj
    dinenoj New Member
    Is there an easy way to remove the rear lower and rear upper engine mounting bolts without the "special tool"?
    Are all the parts of the engine mounting bolt removed counter clockwise? (the all threaded part, the lock nut with four notches in it, the bolt itself pushed right through).
    bike is 1993
