Engine shutting off coming to a stop
Discussion in 'Anything Goes' started by ken98043, Aug 16, 2009.
  1. ken98043
    ken98043 New Member
    Lynnwood, WA
    My bike is an 04. In the last several weeks my bike has shut off a few times coming to a stop. I am just curious if this is something that I should start worrying about or can someone tell me what to do to stop it from happening again?
  2. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    What is your idle RPM set at? I had mine set at 1200RPM and I had the same issue. It would even die from time to time between shifts. I bumped up the idle to 1300RPM and all is well. Manual specifies 1200RPM +- 100RPM so bumping it up to 1300RPM wont hurt a thing.
    To confirm that was my issue I even did the opposite and dropped the idle down to 1100RPM and it made things worse where it would die on a regular basis. As soon as I went up to 1300RPM all my troubles went away and so did my worries.
  3. DGW
    DGW New Member
    Camarillo, Ca.
    I agree I had the same issues and turned the idle up and all was well.
  4. TOE CUTTER
    Idle
    I have mine set at 1400. Makes it easy to leave the light and the others in thr group hate I eat them off the light.Fun for me.:biggrin:
  5. NorcalBoy
    1400 for me as well.
  6. ken98043
    ken98043 New Member
    Lynnwood, WA
    My idle is set at about 1100. I will try turning up to 1400. Thanks for the info guys.
  7. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    I tried 1400 but it was just too high of an idle for me personally. Maybe once I get my exhaust I will be able to stand it a little more :)
  8. 02 VFR Rider
    02 VFR Rider New Member
    had same problem with mine changed the plugs now runs fine and idle back to 1,000 rpm
  9. ken98043
    ken98043 New Member
    Lynnwood, WA
    I just bumped it up to 1400 so I will try that a few days and if I don't like it I will drop it some.
