Erratic needle movement after gauge switch
Discussion in '5th Generation 1998-2001' started by futtie75, May 20, 2025.
  1. futtie75
    futtie75 New Member
    Denmark
    A couple of days ago I replaced the instrument gauge faces on my '98 RC46 from mph to kph (British import to Denmark) and now the needles move quite erratic. At the same time I replaced the seven W5W with LED W5W.
    Symptoms are:
    - The needles move to about 20-50 kph and 1500-2500rpm if I turn on the ignition only (not starting)
    - It's as if they "hang" at some angles, especially the speedometer. Speeding up fixes that with a sudden jerk up to a new speed (not the correct speed though)
    - When the needles are set at 0 (even with ignition on after several tries) they don't return all the way back to 0 after testing speed and revs. Repetitive ignition on/off can drop the needles to lower speed/revs, but almost never to 0
    There's a video (72MB) of one of my first tests here: https://drive.google.com/file/d/1s-8gRRGiVwHqHGX-xKKg0BYgi2R_e-iR/view?usp=drive_link
    Does anyone have an idea about what's the issue? Did I somehow brake both stepmotors (?) at the same time? It's probably the first time the needles have been removed making it a possibility...
    Is there a magic trick or spell that I have to say when reinserting the needles? Should I use a bit of oil on the tip of the metal rod of the needles? It feels like they touch some rough surface at the bottom of the stepmotor. Could the different power draw of the LEDs have a anything to do with this?
    Reading this post https://vfrworld.com/threads/new-gauge-faces.44026/ I should be able to set the needle correctly at 0 in both gauges with some patience. It's the erratic movement that annoys me and makes it hard to keep the correct speed.
  2. Burger
    Burger New Member
    tejas
    are the needle bases rubbing on the gauge faces? try pulling them up just a hair.
    since my bike is currently a basket case i dug my cluster out of a tote and took it apart to see how it worked. the needles can be moved with almost no effort, and gently and smoothly return to zero when released. my suspicion is your needles are too down low on their shafts, causing them to rub. hope this helps.
  3. 50th VFR
    50th VFR Member
    Scotland
    Could be electrical noise from LEDs affecting instruments.
  4. futtie75
    futtie75 New Member
    Denmark
    Thanks for taking a look - I finally got the time and weather to work on my bike again (no garage) and it seems like the needles will return smoothly a couple of times when I lift them and test but will drop back to a point where they scrape against something in the actuator or step motor or what it is. Even with the gauge faces off. Holding the thingy upside down (I unscrewed it) makes the needle return very quickly but in the position that it would have on the bike it seizes after a few times. I'm starting to think if I should give it a tiny drop of oil or something...
  5. futtie75
    futtie75 New Member
    Denmark
    That could definitely be a issue with the ignition on, but the needles also seize without. But I'll test with the incandescent bulbs when the seizing is fixed.
