European ECU differences. 2002 vs 2003-2005
Discussion in '6th Generation 2002-2013' started by Sobu, Apr 21, 2025.
  1. Sobu
    Sobu New Member
    According to the Haynes Manual for the 6th gen VFR 800, the European models "had modified handlebar switchgear and wiring to accommodate hard-wired lighting and hazard lights." As a result, the wiring is also different for the ECU connectors.
    The 2002 models for the European market use the 38770-MCW-D02 (D02) ECU model, while the 2003-2005 use a 38770-MCW-D03 (D03) ECU.
    The wire diagrams attached show that a ground wire and the white and yellow wires to the cam pulse generator have switched connectors.
    My questions are:
    Are there any other changes to the D03 ECU besides rerouting wires?
    Could 2003-2005 European models use the D02 and vice versa if the pins in the connectors are rerouted appropriately?
    If so, what is the pin-wise routing on the D02 (wire colours)?
  2. Sobu
    Sobu New Member
    I'm dum. It's the same wiring. The ECUs are pretty much identical.
    Don't listen to the 2002 wiring diagrams.
