Ever heard of the spoon method?
Discussion in 'General VFR Discussions' started by goinphaster, Oct 25, 2007.
  1. goinphaster
    goinphaster New Member
    California
    It's when you take a spoon and gently push on the padding/foam to take out pinch points in helmets. Would you do it? I only ask because the new Scorpion EXO1000 is a pretty sweet helmet, but it doesn't matter which size I use it has a pressure spot right at my hairline at the top of my fore head. Its thin enough that I think I could get it out using said spoon method. What say you all?
    P.S.- I haven't bought one yet, but i would like to.....
  2. derstuka
    San Diego, CA
    Just make sure you use a clean spoon...otherwise, that is just plain unsanitary!
  3. biker7
    biker7 New Member
    I have. Helmet fit is an art really. Will give you a tip. If you really want to know if a helmet is the right size or not. Remove the cheek pads and evaluate just the hallo fit. In Arais...what I ride...cheek pads come in different sizes. It is common for someone to buy a helmet too big because of how if fits their face. Helmets come in different shapes...Long Oval is what I wear. I don't have a round head...some do. You want to find a helmet that best fits the shape of your head and buy it snug...almost tight. Foam gives over time. A loose full coverage helmet because of its mass and propensity to catch air is a serious PITA. If you have a hot spot or two...spoon it a bit.
    Generally if you adhere to your head shape and mfr sizing you will end up in the right helmet. If you find yourself going one size up because it feels comfortable in the store...be careful what you wish for...you likely won't like the helmet in six months.
    Hope that helps,
    George
  4. Kevin_70
    Kevin_70 New Member
    Diamond Springs, CA
    Had me worried, thought this might be the first ever thread about cuddling on VFR World. :biggrin:
  5. squirrelman
    there's one in every crowd, wiseguy. you b eat me to it!
  6. goinphaster
    California
    I'll censor my threads from now on
  7. rode2rouen
    rode2rouen Guest
    Cuddling???
    My first thought was ".......as opposed to the rolled up C-Note method."
    Rex
