Exhaust compatibility with OEM Luggage?
Discussion in 'Mechanics Garage' started by AZVifferGuy, Aug 22, 2006.
  1. AZVifferGuy
    AZVifferGuy New Member
    Chandler, Arizona
    Has anyone compiled a list of known aftermarket exhaust that work on an '06 with OEM luggage?
  2. Reverend
    Reverend New Member
    St. Charles, MO
    Good question.
  3. AZVifferGuy
    Chandler, Arizona
    If no one has, this would be a great place to start listing aftermarket exhaust that is compatible with OEM luggage! Come on guys... someone must have done this already!
  4. Reverend
    Reverend New Member
    St. Charles, MO
    I'll let you know when I get....correction... when I can afford... some luggage if it fits over my aftermarket stuff.
  5. AZVifferGuy
    Chandler, Arizona
    Is there no one out there that's put aftermarket pipes on a VFR with OEM luggage? If you have, please reply here saying what year your bike is and what exhaust you went with!
    Thanks!
  6. seadooloo
    seadooloo New Member
    New Baltimore, Michigan
    I had the Laser 4 pipe set, the one with the clamps around the mufflers. (I'm pretty sure there are a couple of types of sets made for the Vtec) Although it was a tight fit, it did work with the factory hardbags. Anyone else want to chime in, maybe with experience with the other type of laser set without the clamps which go around each muffler.
