EXhaust help!!!! Laser Xtreme
Discussion in 'General VFR Discussions' started by corey.p.whisenhunt, Jul 14, 2012.
  1. corey.p.whisenhunt
    corey.p.whisenhunt New Member
    Dayton, Ohio, United States
    so i just bought a set of laser exhaust pipes but:
    1. i dont know which inserts to put in i guess there is a street one and a sport one
    2. do the two small pipes get the inserts or just the two large ones
    thanks for any and all help
    also if you can post pictures and sound clips of your LAsers 02+ that would be fantastic
  2. tinkerinWstuff
    do some browsing around. not sure where to find the thread but TOE CUTTER has them on his.
  3. Scubalong
  4. corey.p.whisenhunt
    i sent him a message i hope he does hit this up bc im sick of just looking at all this silver sitting in the box
  5. Scubalong
    How the hell you got a blue VFR...? Is it import or repaint
    BTW I will call Toe and have him contact you. In the mean time read the post, your exhaust might be a defect.
    Did you lay them out and try to fit them first? Take some picture where you having issue so we can try to help.
  6. corey.p.whisenhunt
    ill put pictures up but yes its a re paint its actually a flip paint job it is blue and purple with hints of gold and green all depending on the sunlight
  7. corey.p.whisenhunt
    and here is the rest of the exhaust along with my bulldog who felt left out photo(2).jpg
  8. TOE CUTTER
    You do not want to use any at all, pipes are quiet enough with oot them.
  9. corey.p.whisenhunt
    now that wont hurt the performance or the fuel mileage or anything like that not that the fuel economy is all that important but performance is
  10. Scubalong
    You Will loose a bit in mpg but you should gain a bit of power band. PCiii or PCV is strongly recommend for after market exhaust. Now go put them on and tell us what you think
  11. TOE CUTTER
    With PC and pipes you will be quite pleased with your efforts. It does take a bit of monkeying with the mounting points to get the Laser on straight.........three beer job.
  12. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    I've got the Laser pipes as well.. they are plenty quiet without the inserts installed. I've actually never put the inserts into mine so I can't tell you what it will be like with them in.
    The only problem that I had with mine were that the mufflers didn't have a tight fit around the pipes when mounted. I had some loops welded on and used exhaust springs to resolve that issue and haven't had a problem since.
  13. corey.p.whisenhunt
    it was an absolute pain in the ass not ever putting anything like this together before it was a full case kinda job but i finally got it all done and i love it photo (4).jpg
  14. Scubalong
    Nicely done.................:clap2: Now install the PCIII or PCV with the o2 eliminator and ride her
  15. TOE CUTTER
    I welded hoops and put springs on mine as well.
  16. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    I thought it was pretty easy to put on but I did have a helping hand. Looks great man. Let us know if you havey leaks, especially on the left side.
