Experts to the rescue!
Discussion in '1st & 2nd Generation 1983-1989' started by sel86vf500, Nov 28, 2008.
  1. sel86vf500
    sel86vf500 New Member
    Restoring an 86 VF500, had to replace head gasket. Found something I can't figure out.
    Finally found a head gasket, went to install it today. Since it had been a couple of months since I tore it apart, I went through the shop manual again. It stated that the 2 camshafts were labled INF and EXF, mine are both EXF???
    I was pretty sure which one went to intake & exhaust when I took it apart.
    So, I reinstalled the way I took them out, checked lobe position, lined up sprockets, every thing looked ok. replace cam holders. released spring on tensioner.
    Besides having 2 of the same cams, I cycled the engine using a wrench, but it only goes around albout 1 revoultion, then it locks up. I didn't want to crank on it, but it seems it should keep cycling through. I was turning it counterclockwise, then went back clockwise, still locked up.
    Is this normal or did I screw up?
    I believe I got the tensioner correctly installed.
    Thanks for any help.
    you're cam timing is wrong......try it again.
    be careful or you'll bend a valve.
  3. sel86vf500
    I took the cams back out & tried it again, same thing. I didn't take the chain tensioner back out again, so I think that might be why it is in right. I will take the tensioner out, put the pin back in, and try it again.
    Thanks,
    Scott
  4. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    Wait a minute. Was this bike running before you took it a part??? If not check the other two cylinders and see if both cams are marked INF. There's no way two exhaust cams will work on one cylinder set. You most likely have the valve timing out so far that your valves at some point are hitting the pistons.
  5. sel86vf500
    No, the bike was not running, head gasket was shot. But, it would crank over when you tried to start it. The other cyclinder has the correct cams. INR & EXR, that is why I'm a little confused. It did turnover before, but I agree the valves are hitting the top of the cyclinder. I looked up the hieght of aech cam, and they are different by .004.
  6. masonv45
    masonv45 New Member
    You need the appropriate cams...
  7. loopsandlogic
    loopsandlogic New Member
    Just a pointer from someone that's been in your shoes, make sure you don't mix up your cam covers, cause it will throw off your tolerances with the plastic gauge.
    Cheers
    LL
  8. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    Man, it sure sounds like you were given a set of parts that were thrown together. I'll bet the PO put the exhaust cam in the intake spot and aligned it so that then engine would turn over. You'll need to find a front intake cam, that exhaust cam will not work.
    I wonder if I have one in my pile of VF500 spares.... PM me if you'd like me to take a look.
  9. RVFR
    Dito, you've gone this far now make it right.
  10. sel86vf500
    X-mas project
    I am searching for a FR-IN cam. My plan is to get it back together over x-mas break (Teacher). If any of you have a spare, make me an offer. My bike is an 86, but my engine is a 84 or 85. I think 84-85 cams are the same, but I will check part #'s. Thanks for all the info. That's what makes these forums worthwhile!
    Scott
  11. JamieDaugherty
    Fort Wayne, IN
    Found one for you Scott, check you PM's. In the process I realized that I'm missing a water pump for one of my VF500F's, if anyone has a spare let me know.
