F4 shock mount
Discussion in '1st & 2nd Generation 1983-1989' started by flattrack, Dec 31, 2015.
  1. flattrack
    flattrack New Member
    question about the F4 shock which is a popular replacement for the VF500F junker.
    can the mount with the damping adjuster be unscrewed from the shaft while the shock is charged with gas/oil?
    Would be nice to see a part blowup of how this mechanism works since I have not had one apart.
  2. Terry Smith
    This would be a great question for Jamie Daugherty (www.daughertymotorsports.com) as he rebuilds and sells F4 shocks.
    As far as I know, the rebound adjusting screw has a taper that bears on the end of the rebound needle that passes up into the piston through the shaft. There will certainly be an o-ring seal around the needle within the shaft, but I would expect that the gas pressure would try and eject the needle if you were to remove the adjuster while pressurised.
