Factory Jet kit in your VF500?
Discussion in '1st & 2nd Generation 1983-1989' started by WGREGT, Dec 7, 2009.
  1. WGREGT
    WGREGT New Member
    Looking to see if I can build the Factory Pro Jet kit a bit cheaper thru Sudco. Anyone got one? Would love to get:
    - a scan/pdf of the instructions to see how they suggest initially setting up the needle/clip/jet
    - they TYPE of needle it is, maybe a name or model number? Sudco says they can match it. but I need to know who makes it/model first. I know they have the VD jets for about $4 each, so that's good...
    And yes, I called Factory and gently tried to get the info from them, but they weren't giving out that info...
  2. WGREGT
    WGREGT New Member
    FWIW I emailed Factory today asking if they had replacement parts. Might be another way in....
  3. squirrelman
    Generally, jetkit needles are custom made for the application and can't be purchased except in the kit.
    Do some searching; stepping up the stock Honda needles with appropriate washers, along with changes using stock jets in larger size MIGHT get you 90% of what a proper jetkit would do...........that's what Jamie recommends.
  4. WGREGT
    WGREGT New Member
    Well Sudco can match them if I had one to measure, so they say. Cheap too.
