failing R/R early warning signs...
Discussion in 'General VFR Discussions' started by Streetmachine, Aug 26, 2008.
  1. Streetmachine
    Streetmachine New Member
    My trip meter and clock reset themselves during my ride to work this morning on my 98. The bike has 10,200 miles. Should I be worried? I noticed that I didn't hear the fuel pump whine when turned the ignition over this morning either, but I feel like that could've been my imagination.
    Is this a sign of impending electrical system doom?
  2. Joey_Dude
    Joey_Dude Member
    North Georgia
    It does sound like an impending R/R failure. To be on the safe side you can get a voltmeter and do some tests. In the service manual it shows you to diagnose charging problems. You can get the service manual at VFRD - vfrdiscussion home (register for a free account) and go to the downloads section.
    By the way if the problems the R/R I recommend getting a better wiring harness from Wire My Bike It resolves the fundamental problem with the charging units.
  3. mello dude
    I think first signs are either the battery is not charging and the bike wont start (trips/clock) reset themselves ..or... the charging system fries the battery. Either way .. its R/R time. Grab a new one before bigger damage happens. You might do a search here, there a plenty of R/R threads to peruse.
    Heres one ---- http://vfrworld.com/forums/general-vfr-discussions/15945-best-reg-rec-fix.html
    Something else, its not uncommon for the battery to be toast at the same time too, so have it checked while the new R/R is going in.
    Something kinda weird is on my '98 the R/R went out almost exactly 10,200 miles too.
    Good luck
    MD
