Faulty speedo 97 vfr
Discussion in 'Mechanics Garage' started by fingo, Dec 10, 2019.
  1. fingo
    fingo New Member
    Hello, I have a problem, my speedo works intermittently when my dipped beam lights are on, it works fine with side or no lights, I have replaced the regulator and the battery is charging, any ideas would be gratefully appreciated,
  2. CaptainPugwash
    CaptainPugwash New Member
    Hertfordshire
    What exactly does it do?
  3. fink
    fink Member
    PCB on back of clock have you checked it?
  4. fingo
    fingo New Member
    I will check, but the speedo works with the lights turned off
  5. fingo
    fingo New Member
    The speed starts to register, then drops back to zero, as the revs build, the needle becomes steady, at higher speeds it starts to drop to zero, then again rises, and repeats, if I turn dipped beam off, the speedo works normally
  6. fink
    fink Member
    The wires for your speedo are as such
    Earth Green/black share the same earth as everything
    live black/ brown Common live for instruments and for speedo sensor.
    Pink speedo sensor
    First check all the connections.
  7. fingo
    fingo New Member
    Ok, I will have a look, cheers
