Fender eliminator kit on 07 VFR
Discussion in '6th Generation 2002-2013' started by joeyq4, Oct 10, 2009.
  1. joeyq4
    joeyq4 New Member
    Stamford, Connecticut
    I just installed the fender eliminator kit on my 07 VFR, but could not fit the license plate light back on. I just read a tip about using tape to hold the little 4mm nuts in an open face 7mm wrench to get them started, so I'll make the purchase and let you all know how it went. The instalation took be about 1.5 hours, since I had to find my tools to get started. Nice little evening project. I post some pics to share. Also had to trim my Connecticut plate at the top corners to fit between the 2-bros exhaust.
  2. stewartj239
    stewartj239 Member
    Syracuse, NY
    I just replied under the other thread. It should definitely be easier using the tape. Luckily in NY, the plate fits between the exhaust pipes, but I know others have mentioned that they too had to trim their plates. Let us know how it goes ........
  3. 02 VFR Rider
    02 VFR Rider New Member
    you can spread the pipes a bit as well to get more clearance.
    where in CT are you located I work in the Hartford area.
  4. TOE CUTTER
    Exhaust
    I have installed several of theses and have removed mine several times during my Laser exhaust ordeal.I lossen the pipe at the clamp and reomve both mounting bolts in sub frame and rest the pipes on the tire. Using you finger tips get the two mounting bolts started and tighten with wrench and then install pipes.Takes about fifteen minutes.:thumbsup:
