FI indicator Issues
Discussion in 'Mechanics Garage' started by reg71, Jul 6, 2006.
  1. reg71
    Sikeston, MO
    Okay, I just met another VFR rider locally. It turns out, he stopped by because he saw my bike sitting outside and he needed some help with his. He rides a 99 and here's his issue: The FI light stays on. It turns out he had a crack in the gas tank so he replaced it with a new one, but he still gets the light. So he looked in the service manual about resetting the light, but neither of us could find the plug where it says it's supposed to be in the manual. Does anyone have a clear picture of this plug? Has anyone done this procedure? Is there anything else pertinent to resetting this I should know. Thanks.
    reg
  2. reg71
    Sikeston, MO
    bump...
    anyone?
  3. Classe
    Classe New Member
    Enköping
    FI indicator connect
    Hi. Probably too late but could it be this? On my VFR -99. With blue tape around,a little bit forward is a white connection. Behind the,whats that in english,charging regulator?
    Good Luck
    Classe
  4. reg71
    Sikeston, MO
    I think that may be it. Thanks a lot Classe. We'll have to see if that's it and get his light reset. I'll let you know if it works.
  5. okiengr
    okiengr New Member
    Wichita, KS
  6. reg71
    Sikeston, MO
    you know I saw this and was all psyched up about checkin it out, but I lost any contact info with the guy who had the problem. :) Oh well, either he fixed it or decided to move on I guess.
  7. emon07
    emon07 New Member
    Queens, NYC
    Hey - I have a similar issue. My 2k VFR starts and reves up to 4k rpm. I shut the bike off and the Fi light stays on and the bike will not start. ANy help is appeciated. Thanx!!
  8. reg71
    Sikeston, MO
    I never heard from the guy with the problem again and the only time I have had probs with m FI light was when I was tryin out different maps with the PC2.
