First VFR, long time rider
Discussion in 'Introductions' started by ftl900, Oct 11, 2012.
  1. ftl900
    ftl900 New Member
    Las Vegas
    Just bought a 2000 VFR800 last weekend, not even registered yet. I'm seeing some threads about overheating, and wondering if anyone knows an easy way to put a fan switch on the bike?
    I did with my 85 Ninja 900, and anytime it was hot and I got stuck in traffic, I flipped the switch on to keep the bike from heating up. Worked great.
    Also, I haven't seen anything yet on suspension setup suggestions.
    Michael
    Las Vegas
  2. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    Unless you're overheating I wouldn't fix what ain't broken. See how it goes, the VFR can run hot but it's made that way. It will go to 220+ then the fans will kick in and cool it down. I haven't modified my '99 and it handles the 100+ CA central valley summers fine.
    Are you looking for OEM suspension setup or upgrade advice?
  3. ftl900
    ftl900 New Member
    Las Vegas
    OK, I'll roll with the temp stuff like it is... I just noticed that there were watermarks on the exhaust pipe from a previous overheating episode, and smelled antifreeze while at a stoplight. Maybe it wasn't me tho.
    The bike has stock suspension, and I don't have any idea of how it is currently set. Usually people with similar bikes will get a good starting point for the stock suspension, and that's kind of what I was hoping for.
    Thanks!
