fix for hazy headlight lens?
Discussion in 'General VFR Discussions' started by themoz, Aug 24, 2008.
  1. themoz
    themoz New Member
    North Ogden, UT
    Hey Guys:
    Anyone have any ideas for the best way to clean the "haze" off a headlight lens on a 98 that seems to be from a "clear-kote"?
    I'm not sure if all bikes are like this, but mine seems to have some kind of clear sprayed on coating that has become hazy. In the small spots where its peeled away naturally the lens underneath is clear, but the coated areas are hazy. I've taken my fingernail to it, but most of it is still very firmly attached.:mad:
    Any ideas?:unsure:
  2. Big3
    Big3 New Member
    Lancaster, Ohio
    1500 grit to remove the coating followed by wet 2000 grit, then polish
  3. themoz
    themoz New Member
    North Ogden, UT
    Thanks Big3, I'll give that a try. I have some Novus scratch remover that I tried. I used the #3 (heavy scratch remover) then went over it with the #2 (light scratch remover) with some success. It didn't remove the coating, but it did "buff" it so it was somewhat clearer. Probably just a matter of time before it gets bad again, so if I can get it all of that would be best.
    Just a FYI- the bottles say not to use it on things like lenses.
  4. _oxygen_
    _oxygen_ New Member
    Cary, NC
    A friend of mine got some kind of kit from the autoparts store for his cr that had plastic lenses it was probably the 1500,2000 grit as it had 2 sets of sandpaper products followed by 2 polishes the polishes had a pretty decent solvent smell to them.
