Flat Battery
Discussion in 'General VFR Discussions' started by VFighteR, Dec 25, 2009.
  1. VFighteR
    VFighteR New Member
    Melbourne , Australia
    Hi Guys - Just wanted to know, If my battery isnt charging properly, would it be the regulator/rectifier on my 1995 750F or something else? How would I trouble shoot this as my ignition totally failed, and the horn wouldn't work when ignition was on so I suspect the battery was flat - Got it going after a roll start, and was showing 12.5v on the way home
    :confused:
    Laws of probability point to the R/R as the usual suspect.
    However, very often this issue is related to melting/burning at one of two connectors: the plug with 3 yellow wires between stator and R/R or the red plug from main wiring harness atop the starter relay, so look there first.
  3. VFighteR
    VFighteR New Member
    Thanks Squirrelman - Chrecked em both, they ok. I think its the R/R! Spew! Hd this once before on an older VFR
  4. squirrelman
    Well, Matey, you're not considered a veteran VFR rider 'round 'ere until AFTER you've replaced your SECOND R/R.....
