Flat battery
Discussion in 'General VFR Discussions' started by Kavo, Nov 18, 2013.
  1. Kavo
    Kavo New Member
    Wolves
    Hi
    Is it ok to jump start My RC36 with a car booster battery
    If that makes any sense lol
  2. TOE CUTTER
    It is safe to jump with a car battery but I would only do so with the car NOT running.
  3. Scubalong
    +1 for Toe suggestion
  4. diVeFR
    diVeFR New Member
    Spring, TX
    I think the next question would be why is it dead. And also what Toe said.
  5. squirrelman
    Recharge the battery you have to see if it will revive. Next check charging voltage at 5000 rpm. It makes little sense to just drop in a new battery without testing the charging system at the same time.
  6. Maggot
    Maggot New Member
    Park Ridge, IL
    Yes to what they all said!
  7. Kavo
    Kavo New Member
    Wolves
    The battery is dead because its not being used all that much only about a mile to work and not used at weekends
    Thanks for the help
  8. Badbilly
    See "battery tender UK" on Google.
    Also:
    The Toe
    Know
