Flat tire Fix
Discussion in 'General VFR Discussions' started by chomper, Feb 19, 2008.
  1. chomper
    chomper New Member
    Greater Vancouver Area B.C
    Managed to get a flat tire today, limped into auto parts store and fixed with one of those tire plugs and went on my way. should i take it in and get a better professional fix? any one else riding around with one of those plugs in their back tire or are they just a temporary fix. not a nice feeling to get a flat on a bike while your riding it.:frown:
  2. reg71
    Sikeston, MO
    the only time I have ever gotten a flat I went ahead and changed the tire. I guess I would be ojay riding it easy until I could get a new tire, but I wouldn't want to run on a plug for a long time. for me, it's just peace of mind to know that your tire is whole...
  3. Fizz
    Fizz New Member
    San Diego, CA
  4. chomper
    chomper New Member
    crap i don't want 2 buy another tire lots a life left at least another season. reg now you got me worried. i almost dumped it on a corner i thought something didn't feel right first flat i ever had on a street bike . i cant stand local bike shop guys a real A HOLE i wouldn't trust him to wash my bike
    vfride that looks like the plug i used its not the worth the risk ill have to go get it fixed. it did work though
    thanks guys
  5. RVFR
    Okay here's my take on it, first depends on where on the tire and what made the flat then how much damage was done to the carcass. I have run a many thousand miles on plugged tires. I knew the risk and kept a keen eye on it. all thou in my cases they where in good spots, clean puncture between the tread pattern, no damage to the tire, so really wasn't much risk at all. Answer those questions, then you'll have your answer. Other hat trick is finding a tire shop that will do the work. Yea those tire plug kits you get at the store, IMO, are only to get you home. so have a professional do the work, again if you can find one as its a liability issue for a many shops. GL
  6. Fizz
    Fizz New Member
    San Diego, CA
    I used the exact same kit in my the link I posted earlier to fix a nail hole in one of the tires on my '92 Celica, it's been in and sealing for the past 1.5 years now almost. But I mean, it's a car, with 4 wheels and a helluva lot more contact area with the road and less bad things happen if it were to go flat again (I carry a plug kit and one of those cigarette lighter air compressors in my roadside kit).
    I wouldn't trust a plug on an MC, plus I don't think I can use that plug on my older Bias ply tires that are on my bike in any event.
  7. chomper
    chomper New Member
    Thanks RVFR thats what i wanted to hear. that someone else was riding around on a fixed tire. did try a tire shop they out right said they dont touch Bikes. it was just a simple nail puncture on center of tire.will find some one to fix it with a better plug
    thanks
  8. Mac
    Mac New Member
    NC High Country
    Hey Chomper,
    For your own safety, get a new tire. I wouldn't trust my life to a plug. From what I've seen of Canadian Cagers, your taking enough risk just sharing the road with them.
    Mac
  9. chesthing
    chesthing New Member
    Colorado
    A failed tire at speed is one of those few things completely beyond our control that can cause a crash - a couple hundred bucks is not worth the risk.
  10. masonv45
    masonv45 New Member
  11. derstuka
    San Diego, CA
    Chomper,
    I got a flat tire (nail) in a tire with only 1500 miles on it last year. Tire still looked new and I didn't want to replace it already. I plugged it (from the outside) and put some sealant on it, and it lasted another 2000 miles. Never lost any air hardly at all during that time, and that was only at the very end that it did lose any air at all. Like RVFR said, the key is to see where the punture is, what kinda of puncture, size, tread left on the tire, and so on. Then just keep an eye on it. I would not do track days on a plug, but if you do a good job plugging it, keeping an eye on it and any drop in pressure, I would not stay up at night worrying about getting a new one. Some people replace a helmet after it falls off their bike, and (depending on how it looked) I have not. Of course the safest (and most expensive) way is to get a new tire, but I probably would not do that unless it was well worn and near the end of it's life.
    If it was me, and I wanted to use the best type of plug, I probably put a tire patch from the inside of the carcass. You would need to do this yourself though, as no shop will repair a tire. They do not want the liability. You would have to have them take the tire off, then clean and patch it, and they have them remount it. Then just keep an eye on the plug periodically, and pressure if it drops noticeably, and go from there. If you do use a plug, just be sure not to wear it down excessively far into the tread. Be a little modest and change your tire earlier than you normally would.
    Then again, I am just a daredevil that lives on the edge! It really did not concern me that much that the tire was going to "blow up" or anything, just that it might slowly start to lose air. Again, this is all what I would do depending on the severity of the puncture.
  12. MAJBuzz
    MAJBuzz New Member
    New guy still trolling here until I eventually decide on what color VFR to get, but my Duc had a flat about a year ago and I had a plug put in to get me home. The plug was near the outer edge of the tire, and about three weeks after it went in it came out one day after a series of corners ( I presume that's where I lost it). Mechanic told me that due to varying stresses on the tire that they sometimes will come out if the original job may have been marginal.
    Just my experience, but from now on I will put new rubber on as soon as possible.
  13. derstuka
    San Diego, CA
    Never had that happen on a "quality" plug job, however, I would probably replace the tire (or use a patch from the inside) if it was on the outer edge of the tire. Too much flexing out there.
  14. v4pwr
    v4pwr New Member
    cleveland, ohio
    i havent had a flat yet but i would suggest a new tire. like other people said i dont think it will blow up, probably just go flat again. but i would replace the tire if it was mine afterall you only have 2 tires and you need to rely on them for a safe ride. thats my 2 cents
  15. Taz
    Taz New Member
    from SoCal, now in Utah
    1. store patches are temporary
    2. location, location, location !
    3. Fronts quick plugs again are temporary & speeds down, & replace tyre asap !
    4. Rear tyre, used for city/commuting, or tearing up the twisties.
    City/ local commuting they will be OK with a "professional plug (depending on tyre damage & location) that's a special plug put in from the inside of the tyre with a head on it that seals & prevents further tearing of the carcos.
    Twisties & any speeds over 80 mph (or above 120 kph for you Canucks) you need to replace the tyre for safety reasons :director: .
    You could get lucky & push the bikes in the twisties & @ speeds & the tyre holds & lasts "BUT" you have to put in prospective if your life & the possibilities of others lives & property is worth the chance :eek:
    My advice is patching is for to get you home if 100 miles or less, then replace the tyre for your sake & others :biggrin:
    5. have the tyre pro patched & sell it to stunters & get back 50 - 75 bucks.
    I do this with D.O.T. take offs & patched street tyres all the time.
    They go through tyres like candy & @ there low speeds the patches won't matter (I sell them as patched great tread tyres good for stunting ) because they can burn of the tread in a day's ride on them.
    If the local stunters don't buy them, I put them on Fleebay & there snatched up quickly, by other stunters:smile:
