Flexible exhaust gasket 18532-MT4-000 .No longer available ?
Discussion in '3rd & 4th Generation 1990-1997' started by chickenstrip, Mar 30, 2016.
  1. chickenstrip
    chickenstrip New Member
    My gen 3 needs a new one.
    Any body come up with an alternative?
    None in Australia or from honda japan.
  2. Dead Eye Dick AKA Carpy
    Dead Eye Dick AKA Carpy New Member
    Chill Out City
  3. thx1138
    thx1138 New Member
    Perth
    if you deal with remarcables be prepared for disappointment.
  4. V4toTour
    V4toTour New Member
    goop up some permatex ultra copper around the old one and call it a day.
  5. chickenstrip
    Nothing left of the old one.
    But will have to work something out if this isn't a go! [DLMURL]http://www.remarcables.com.au/Motorc...et-Flexible-Ex[/DLMURL]
    Used used an old number plate and Selley's 401 to fix the rusted collector box on a previous vfr I owned but this bikes is 2 good for that sort of bodged up repair.
  6. V4toTour
    V4toTour New Member
    The gaskets just one of those donut things right? Take one end of the joint down to your local auto parts shops and root through their supply. You'll probably find something generic close enough that you can then whittle down a bit and seal up.
  7. chickenstrip
    Yes was just thinking that .Will give it a shot.
  8. chickenstrip
  9. chickenstrip
    Just to update these work really well.
    They don't look anything like right but squish up under pressure and seal perfectly.
    I took the springs off and fitted shorter bolts to get a good crush and then fitted the original bolts and springs .
  10. ridervfr
    Nice job sourcing those, I have an interest in these bikes so I follow threads regarding them. I never had an issue with these gaskets on any of my gen 3 bikes, I did win an auction for a slip on pipe which had the original one stuck in the pipe, I ended up chiseling it out and stuck it in the attic as it sucked (you can't always win on ebay auctions.) I ended up using some springs off it though :mech: Waiting to take my 91 out a little ride but dont wana get caught in the rain on my day off with it :loco: 93 gets more regular use as I go to work on it once or twice a week. Cheers
