Float Valve Opinions
Discussion in '1st & 2nd Generation 1983-1989' started by hoganth, Mar 31, 2011.
  1. hoganth
    hoganth New Member
    The Villages, Florida
    I purchased a carburetor overhaul kit from V4 market recently and the new float valves are stamped with #1.6 the old valves are stamped #2.4 is this going to cause a problem?
    Thanks for your assistance.
  2. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    Are they the same physical size?
  3. hoganth
    hoganth New Member
    Physically they look the same. I installed one and it seemed to fit O.K., not sure about the other dimensions, will have to get the old dial calipers and check it out.
    I am curious though as to what these numbers actually mean
  4. squirrelman
    Numbers refer to inlet hole size, therefore max fuel flow rate into carb.
  5. hoganth
    hoganth New Member
    Just got back from looking at that. The 1.6 has a smaller diameter inlet, and the 2.4 is larger. everything else seems to be the same.
    What would be the impact of using the smaller ones? Or should I use the larger ones only?
  6. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    Possible fuel starvation under heavy type loads, high rpms and possible being lean because the bowls are not filling fast enough. When it leans out it will run hotter, ping or if you have timing retard that will happen. Down on power at times.
    Get the correct size or drill them out only if the needles for the 2.4 and 1.6 are the same.
  7. tinkerinWstuff
    verify if the 1.6 is correct before getting carried away. Honda may have changed what was recommended for that carb or some other clown with his dirty paws may have put the wrong part in prior to you being involved with this motor.
    I wouldn't recommend drilling out a seat unless you have a lathe in your garage. Even though you're just opening up an existing hole, it will no longer be perfectly perpendicular or centered and likely not to seal well. Just my opinion. I'm sure someone's done it, I just don't recommend it.
  8. hoganth
    hoganth New Member
    Thanks guys for your feedback. My instinct tells me that the float valve being over 30% smaller would have some negative impact on the fuel mixture. I sent an email to V4 about the size discrepancy but have not heard back yet.
    Thanks again,
    Tom
  9. tinkerinWstuff
    Could have been problems where the high flow from too large an orifice was difficult for the float to shut off consistently. Honda may have had a TSB that recommended a change to a smaller orifice.
    Don't make assumptions, wait to hear back and know for sure. You could try checking the online fische at servicehonda.com or similar to see what part is listed there. We always tend to think that bigger is better but I'm sure you can think of a few examples where that's not always the case.
  10. Dukiedook
    Kansas City, USA
    Hehe, Texas comes to mind.:wink:
  11. hoganth
    hoganth New Member
    Did some checking on old ebay carbs I purchased a few months ago, from 1983 VF750's. Surprise to me they all had "1.6" float valves installed! I suspect at this point the carbs on the bike are not the original. Further amplified by fact that when I had this thing running it really sucked the gas at moderate speeds. Does anyone happen to know or can verify that for the 83 VF750F they came with "1.6" float valves. Also the numbers stamped on the carburetors are different than the ebay ones. Who knows what has been done to this bike after nearly 30 years. The P.O. doesn't know anything about the history as he bought it from someone else.
  12. donald branscom
    donald branscom New Member
    Guerneville CA
    Sometimes two motorcycles (HONDA) use the same exact part but have different numbers. The part numbers just show which bike it was for.
    EXAMPLE the clutch spring washer on the VF1000R is also used by the VF1100.
    Rhe carbs and many of the parts are the exact same parts for the VF1000F/R and VF1100's.
    I am running VF1100 carbs on my VF1000R. Same exact parts. Mainjets may be different. Thats all. I have 125 mains but could go all the way up to 150 mains if I want to, but I do not run the bike at full throttle often. It would just use up a lot of gas.
    I have two .060 washers under the needles though to give me more power in the mid range. !/4 throttle to 3/4 throttle. and very good throttle response. spark plugs look perfect.
  13. tinkerinWstuff
    Shouldn't matter what carb you bolt on, the bike should use the same amount of gas for a given distance, RPM, and load. As long as the jetting is adjusted to match the engine the carb is on. Every engine requires a specific air/fuel mixture ratio. The amount of air/fuel that an engine is capable of drawing in is a factor of the piston diameter, cylinder stroke, and cam profile. The carb jetting is adjusted to ensure that the proper mixture is supplied during different RPM ranges.
    Different carbs can occasionally allow for higher peak horsepower because a larger bore in some cases will allow better air flow at high RPM.
    So, your engine using an un-ordinary amount of fuel is most likely a factor of the carb not being adjust properly and less about what part number it is.
  14. hoganth
    hoganth New Member
    Thanks guys for your feedback! I'm going with the new 1.6 float valves along with all the other SM specs. Let you know how it turns out when finished.
