Float valve(s) for 1987 VFR700F2
Discussion in '1st & 2nd Generation 1983-1989' started by cbx1260cc, Jan 17, 2017.
  1. cbx1260cc
    cbx1260cc New Member
    Flowery Branch GA
    Are there any other options other than OEM (Read K&L Maybe) for a set of Float valves for this bike??
    Honda; as far as I can tell, only sells a complete set-----Part number 16011-MM4-004.
    See Tourmax (from England) might be a source but prefer not to wait weeks for them to arrive.
    I would Appreciate help / suggestions.
    With thanks in advance.
    Rick
  2. savedrider
    savedrider New Member
    Southern California
    When I did mine it was Honda parts. How many do you need? Is the set you mentioned (4) float valves?
  3. cbx1260cc
    Flowery Branch GA
    Savedrider,
    Rebuilding a set of Very NASTY carbs and thus need Four .
    Do you happen to have a set available?
  4. cbx1260cc
    Flowery Branch GA
  5. savedrider
    Southern California
    Thanks for the link, looks to be some good items there for sure! Glad you found what you were looking for. I checked and I do have my original float valves I kept when I went thru the carbs years ago. I think you're better off using new parts, but if you're still in need let me know.
  6. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
  7. savedrider
    Southern California
    That site has a lot of great information. Thanks for sharing!
  8. squirrelman
    In practical terms, the needle seats don't wear (rubber vs. brass) and shouldn't need replacement, so buy needles only and save some of $$. K&L Supply sells a set of 4 float needles that work well on the VFR and are inexpensive. Many places sell cheap needles sets on ebay. Sorry i don't have the part any part #s. :cool:
    I usually don't trust aftermarket, no-name parts, but the K&L-suppled items i've used so far have proved acceptable.
    Always best to leak-test carbs b4 mounting them up.
