footpegs
Discussion in 'Gear & Accessories' started by v4pwr, Apr 16, 2008.
  1. v4pwr
    v4pwr New Member
    cleveland, ohio
    has anyone replaced their o.e. pegs with aftermarkets. i seen some from L.P.
    and was tempted to try them to see how they look and feel over the originals. but i wasn't sure if the springs on the front footpegs would work with aftermarkets. how about the rears can they be swapped out also?:confused:
  2. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    I just got some off ebay, Ill let you know if the fit as soon as they show up... I didnt feel like paying $38.00 for one of Honda's but We will see.
  3. Knife
    Knife Member
    Downingtown, PA 19335
    I replaced the fronts on my 5th Gen with Buell pegs, which are about an inch lower than stock. Had to do a little grinding to get them to fit, but it was an easy swap out (took maybe a half hour). Cost about $30.00 for the pair from a local Harley dealer.
  4. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    5th Gen pegs are different then 4th Gen and dont work too good unless you have a zip tie......Thanks Reg!
  5. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    Just got the foot pegs from Ebay that said they fit the Gen4 but no go! So I guess Ill buy a factory one.
  6. derstuka
    San Diego, CA
    I bought some knurled aluminum rounded ones off of fleabay....I couldn't find them as of now, but I like them...a lot lighter as well.
  7. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    Thats what I got but do not fit the 750 as stated- you need another set :)
  8. olivino
    olivino New Member
    New York
  9. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    The 05 and 07 should take the same pegs, you could check the online parts catalogs and see if they call for the same # or call your Honda dealer if you got a nice parts guy.
  10. squirrelman
    I found that CBR 600 F3 or F4 footpegs will work on a Gen 4 if you do some filing....springs work too.
  11. reg71
    Sikeston, MO
    that was actually a footpeg from a ninja that I gave you. I took it off Terri's EX250...
  12. reg71
    Sikeston, MO
    which ones did you get? I might get them as spares... someone wore off the hero tabs on mine pretty bad...
  13. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    They have replaceable ends and are silver and round..... need pics?
