Wanted For an '86-'87 VFR700F - both front turn signals and both mirrors
Discussion in 'Classifieds' started by Bazza, Nov 8, 2023.
  1. Bazza
    Bazza Member
    New Smyrna Beach, Florida
    Looking for a pair of front turn signals (including the rubber stems) and a pair of rear view mirrors.
    These have to be the factory units - not aftermarket.
    White in color for the mirrors & signals would be perfect but am open to other colours.
    Thanks!
    ~Bazza
    What color signals are you after, white or black? And you want the OEM front stays that are about 3 feet long? /s
  3. Bazza
    Bazza Member
    Thanks, Capt.
    White signals would be my preference......but ultimately I could re-paint whatever I can get if need be.
    The long stems....I hear ya.....:Pound: - but yes - looking for the factory stems too......
    Let me get the "box" down and look at what I have. If painting is an option I likely have everything you need except maybe the stays. But I MIGHT have those too, cuz they aren't going on ANYTHING I own. The rear stays are the perfect length for the front, iirc. But I understand wanting factory correct items.
  5. Bazza
    Bazza Member
    OK thanks - that'd be great. I'm a good partner to transact biz with, FWIW. :)
  6. Bazza
    Bazza Member
    This is a pic I found on the Internet. Those are the long stalks you are talking about, right?
    Sure, they are a bit long but I'm OK with them. :)
    Much better:
  8. Bazza
    Bazza Member
    Yeah that's beautiful!
  9. Bazza
    Bazza Member
    Quick update, Cap.....if you have these signals with the short stalks in Blue....that would be fine. I just realized I already have a pair in white with the longer stalks that are on the rear of one my Blue '87's....so just need to replace those when I move these to the front of my White bike.
    I'm assuming the fronts and rears are interchangeable....right?
    Thanks!
    Signal housings were only offered in Black or White. Those sure look like the front FII signals. Front sockets are 3 wire for the running light. You can swap the stays to account for the "droop".
  11. Bazza
    Bazza Member
    OK thanks for the helpful info. I should have known that about the colors. I will take a look at my droopies and see if they have the three wires then, so I can use them on the front of the White bike. Chances are they do, I'm guessing.
    Will advise.
  12. Bazza
    Bazza Member
    FYI: the rear signals I have only have 2 wires, so I'm still looking for a couple of fronts, along with the mirrors.
    The length of the stalks long or short doesn't really matter to me - whatever I can get.
    Thank you!
    ~Bazza
    But you have 4 white housings? You can still run those 2 wire up front, you just won't have running lights.
  14. Bazza
    Bazza Member
    Sure.....but I'll wait to see what you come up with and go from there. Maybe you will find what I need in your "box" (?)
    Thanks!
    If you need / want white housings, you should consider those 4 "the ones" if they are in decent shape and swap stays and sockets to accommodate.
    If some slight repair / fill, sand and paint will get you set for the blue bike, then I probably have something. Nothing trashed and perhaps quite usable as-is. I'll get the box down this weekend and sift thru it.
    Bazza likes this.
  16. Bazza
    Bazza Member
    Sounds good - yes I will take you up on your offer. I appreciate it! :)
    And the mirrors too, if you have those.....:)
    NS125R mirrors have the correct base to mount. The shape of the mirror housing is different, but they are an option as good original VFR mirrors are hard to come by for a decent price.
    squirrelman likes this.
  18. Bazza
    Bazza Member
    OK thanks - good to know. I will wait and see what you have. Would prefer the factory for everything, where possible.
  19. Captain 80s
    I will not be releasing any decent mirrors, I can tell you that right now.
  20. Bazza
    Bazza Member
    OK that's fine.
    The signals would be very helpful if that works out.
    Thanks!
