Fork install with F2 wheel question
Discussion in '1st & 2nd Generation 1983-1989' started by waynea, Aug 11, 2010.
  1. waynea
    waynea New Member
    I am ready to reinstall the forks on my VFR750F and have a question for those of you using F2 wheels. Do you align the grove in the forks with the top of the fork bridge, the stock setup?
    I did a quick check and the diameter of the F2 wheel/tire is just about the same as a stock 86 VFR750F.
    Stock 110/90-16 = 19.89” diameter
    F2 120/60-17 = 19.83” diameter
    The rear stock wheel/tire is about 1 ¼” taller then the F2.
    Stock 130/80-18 = 22.04” diameter
    F2 160/60-17 = 20.77” diameter
    I have the modified rear shock from Cobalt, the one with the longer lower joint. I doubt it makes up for the 1 ¼” drop from using the F2 rear wheel. I’m just curious how much others are dropping the bridge on the forks when using F2 wheels.
    Thanks,
    Wayne
  2. TOE CUTTER
    Are you installing the F2 forks ?
  3. waynea
    waynea New Member
    No, using stock 86 VFR750 forks.
