Fork oil
Discussion in 'Mechanics Garage' started by keny, Feb 15, 2007.
  1. keny
    keny New Member
    Finland
    city of Karjaa, Finland North Europe
    I wounder what rate suspension oil to use in fork. Haynes manuak sayt ATF (automatic transmission Fluid) or Pro Honda Suspension Fluid SS-7. But ot does not tell what weight oil, 10W, 15W or 20W ??
    Anyone know?
    <--- what bike for....
  2. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    If it originally called for atf then using a 5wt oil would be best IMO.
  3. RVFR
    SS-7 is a 5wt, yea for those that change out the fluid a lot, I've heard Auto Tranny fluid works fairly well, ala race /track bike guys use it a lot. I'm using Bel-Ray 7wt. this time around, I've a whole different set up now :biggrin: I also change mine once a season.
  4. keny
    keny New Member
    Finland
    Thanks for replays.
    Might go for thicker to get more control then
  5. RVFR
    Oh SS-8 is a 10wt. thats why I ended up going the way I did. I didn't fluid that was too much thicker, and most that I talked to warned me by going to the 10wt. I may find my ride to harsh, so did the rebuild valve and spring first then tried it with the SS-7, but knew I needed it to be a wee bit thicker in the oil department after I put the miles on, so during the F3 swap thats when I jumped up to the next wt. which IMO since Honda didn't have it, was to go with another brand. which in this case was Belray
  6. SierraVFR
    SierraVFR New Member
    Citrus Heights Ca
    I have read so much about ATF use, but not much about anyones favorite. 5wt or 7wt Bel Ray or whatever....
    I do Normal 1 up riding at 150lbs on a 1992
  7. SierraVFR
    Citrus Heights Ca
    I just completed putting Repsol 7.5 Wt in the forks. I did not get 386ml out of the forks, but I am sure the residue in the drain bucket and rags must account for some. Interesting note: The manual calls for 13.4 Oz or 386 ml. BUT conversion charts indicate 13.5 Oz = 399 ml. I put in 390 ml. and I am hoping for the best. The measuring process involves removing the springs, so I took a short cut by not doing that since I am not replacing the fork seals. The next ride should prove to be very interesting and hopefully uneventful.
  8. VFRBenny
    VFRBenny New Member
    Oakland, Cal.
    Mobil1 had some ATF that specs out really nice. Right around 10 wt.
  9. SierraVFR
    Citrus Heights Ca
    I completed reassembly and I had a chance to test ride on Sat. The front end is firmer. Braking is quite a bit different as the front does not dive so harshly. Ride is smooth over bumpy back roads. Dips and bumps in the road that are felt do not jar the chassis. I would say for a 150 lb rider 7 wt is a good choice. I left the preload set at 3 and 1/4 grooves. The truth will really be known sometime this summer on the twisties. For now I'm glad to have it back together in the corner of the garage.
