fork seal measurements
Discussion in 'Mechanics Garage' started by Scouser, Dec 2, 2018.
  1. Scouser
    Scouser New Member
    Carlisle Ontario Canada
    Sorry if its been posted before as I did a search but didn't find anything.
    Does anyone know the fork seal measurements. O.D. x I. D. x Width
    1986 VFR 750
  2. Terry Smith
    New Zealand
    I have a set in my parts drawer. I'll check when I get home.
  4. NorcalBoy
    You nailed it Mr. Smith, I had a hunch the OP was looking for something other than OEM replacements, hence the request for dimensions. The OEM seal and wiper are still available as a set from Honda, 1 set per leg. Apparently, the same seal and wiper were also used on the 90's CB500.
    Not like we need it, but I did check anyway.
    37x50x11
  6. Scouser
    Scouser New Member
    Thanks I just want to pick some up before I remove the old ones. Hope to get some from a bearing and seal supplier. I need to get some bead seal I think is 4mm to make a seal gasket for the air intake cover top and bottom groove. I tried to look one up to purchase but most parts suppliers don't list it that I can see.
    I bought the bike a few years ago but have been to busy to look at it. It only has 5000km on it. The old owner put it in a garage for 25 years. They rode it in turned off the key and left it like that for the mice and old gas to do what they do best. Nice little winter project. However its a major project.
  7. Diving Pete
    Where's the pics of it? We love projects....
  8. Scouser
    Scouser New Member
    Seized cylinder. Seized valves. Seized carbs. Carb casting eaten away. Tank fully gummed up. Seized brakes. fun times.
    Diving Pete likes this.
  9. Scouser
    Scouser New Member
  10. Diving Pete
    Yep that will keep you busy
  11. Blackslide
    Blackslide New Member
    Finland
    Wow, since it requires a ton of work anyhow, it might be a good time to go big bore on that one, or is it a stroker, or both?
    Riding on the storm
  12. Scouser
    Scouser New Member
    I ended up getting an other engine and full set of carbs. I will rebuild the original motor some time later. I wont to keep it as original as possible. (No Mods). Frame, Motor, Carbs are all cleaned up. Tank inside is almost done cleaning. Made a few gaskets. O rings on order. Bead seals still to be made for intake covers. Fork seals, and more gaskets on order. Bearings to be ordered and so on. Just a winter project to keep me busy.
