Forme NJ Gov McGreevy In Divorce Court
Discussion in 'Anything Goes' started by KC-10 FE, May 5, 2008.
  1. KC-10 FE
    KC-10 FE New Member
    Deleted...
    KC-10 FE out...
    :plane: :usa2:
  2. drewl
    drewl Insider
    Virginia Beach, Va
    NJ=Nut Job
  3. nozzle
    nozzle New Member
    Southern Maryland
    Wiped, since it make little sense without KC's start... you didn't miss much.
  4. derstuka
    San Diego, CA
    You have such a way with words KC..... :biggrin:
  5. KC-10 FE
    KC-10 FE New Member
    Name that movie.
    KC-10 FE out...
    :plane: :usa2:
  6. NorcalBoy
    once again, norrow mindedness, and the inability to attempt to understand the entire set of circumstances and allegations, leads to name calling. pathetic.
  7. NorcalBoy
    hehe i clicked on the link and responded because i have the same ability to post my view, just as you do. i knew all along that a view different from yours would provoke an attack, you did not disappoint. child psychology seemed to work perfectly.
  8. NorcalBoy
    Bring it on, if you would care to have a battle of wits with me, you might want to consider getting some help. As a representative of the United States Air Force, i have routinely found your comments to be quite unbecoming a person who wears a uniform representing this country. on many occassions i have actually been embarassed, not by the comments, but for you, as a person. you can choose to act however you like, but it is something you might want to consider.
    the "Pole Smoker" comment was completely unnecessary, unless you are trying to impress your buddies at recess. i appreciate your right to free speech, however, i'm quite sure that it is not reciprocal. if i was to stereotype, which i won't, based upon your statements, i would have to assume that there is a more broad based problem of intolerance, homophobia, judgmentalism, and egomaniacal behavior. if you would like to be treated with respect, you must act respectfully. I for one will treat you at face value based upon your interactions with the other paticipants of this forum. btw, i'm sure your commander would be very proud of you.
  9. KC-10 FE
    KC-10 FE New Member
    Hate to break this to you, the posts were very obviously a joke, a stab at NJ, low brow humor & political griping based on the fact that NJ is so far past corrupt that there isn't an adequate defintion for it.
    You call me intolerant but you then turn right around & criticize my posts & state your disapproval of me & my posts. That sounds just like intolerance to me. You could have just moved on but you didn't so again, your intolerance surfaces. If you look in the mirror, that's hypocricy looking back.
    To please you, I have deleted all the offending posts. I sincerely hope your attempt to make yourself feel superior at my expense has proved fruitful. I am a very bad person. :frown:
    Thanks for being a buzz kill. You must be great at parties.
    I shall retire & cry myself to sleep on my huge pillow.
    KC-10 FE out...
    :plane: :usa2:
