Framesliders For A 1999 Vfr
Discussion in '5th Generation 1998-2001' started by warchild, May 7, 2006.
  1. warchild
    warchild New Member
    DELAWARE
    Does Anyone Know Where I Can Get A Set Of Framesliders For A 1999 Vfr That Can Go In The Place Of The Fairing Screws, So I Dont Have To Cut The Fairing Or Anything..
    If So, Where Can I Get Them.....
  2. michaelt863
    michaelt863 New Member
    All of my research for a "bonafide" frame slider will require some sort of
    modification to either the side fairings, radiator overflow recovery bottle,
    and/or both! Check here w/fellow members....there's tons of data/links
    avail. for you. HOWEVER, IF you're looking for just peace of mind from
    parking lot/low speed tip-over, check E-bay.....a company from Japan
    may have just the answer, using our stock unmodified fairings! Hope this helps.
  3. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    I have been looking for the same thing. I plan to hit the track alot this year and a little insurance seems prudent. I'm thinking of picking up some track plastic so my pristine road plastic stays just that. If I find a soloution, I will let you know.
    :bolt:
  4. warchild
    warchild New Member
    DELAWARE
    Thanks For The Help
    Thanks For The Help. I Been Looking For A Long Time, So Any Help Will Be Greatly Appreciated......
  5. Kamzilla
    Kamzilla New Member
    Queens, NY
    HPS makes sliders that don't require you to cut the fairing. I'm looking to pick a set up myself soon. Yes, they're pricey, but cheaper than replacing full fairings.
    www.bikehps.com
