Fried Clutch!
Discussion in 'Mechanics Garage' started by Foxracingmx79, Jun 30, 2008.
  1. Foxracingmx79
    Foxracingmx79 New Member
    Bloomington,IL
    I have an '06 VFR. This past weekend I had the chance to take my beloved bike down a drag strip about a half dozen times. She did great. It happens that i was at all harley drags and had one of the few sport bikes on the grounds. The track was open to spectators on Friday night. You can imagine the garbage these v twin guys gave me. So when the oppurtunity came about for me to go head to head with a V Rod, you know, the "fast" harley, I gladly accepted. The problem came after a few burn outs and some hard runs. I parked the bike overnight and when I rode it the next day the clutch was slipping bad under acceleration. Bike only has 6300 miles so you can imagine my frustration with both myself and the bike. I've had CBR's that had been much more mistreated than this bike and held up. I generally baby this darn thing. So my question is, Is this a common thing? Due to the weight of a VFR? And is it most likely just the friction plates or is there just no way to know until it's apart? And what is a good aftermarket clutch kit maker? How long does a job like this take and how difficult is it to do myself?
    Any help at all would be great.
    Thanx,
    Justin
  2. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    I do not think it is common. However, have you tried to bleed the clutch line? If that doesn't help, then I will say that changing the clutch is not a difficult job at all, if you are mechanically inclined. When i replace a clutch, i do both sets of plates, steel and friction. I cannot say what is the best brand. I forget what the dealer sold me, but it held up well under abuse.
  3. reg71
    Sikeston, MO
    I don't think it's incredibly common, but I did it to my 98. I did a write up on changing to a barnett clutch plate set a while bike. It should be pretty easy to search out. do advanced search then posts from user "reg71" and keyword Barnett. I think that should find it for you. If not, let me know and I'll track it down...
  4. ILVFR75
    ILVFR75 New Member
    Illinois
    Justin,
    Sorry to hear about your clutch troubles.
    I'm also located in scenic Bloomington, IL. Drop me a line if you wanna ride sometime. Also, if you know of any good twisty roads around here, please let me know where they are located.
    Cheers,
    Jeff
  5. Craig in Alabama
    Craig in Alabama New Member
    Madison, AL
    Hi Justin,
    More importantly, how did the VFR do against the V-Rod?
    Inquiring minds and all that...
    Craig :smile:
  6. Foxracingmx79
    Bloomington,IL
    VFR stomped V Rod. The track clocks were'nt running but the guy with the stop watch told me 12 sec. flat. I was doing 118mph so I think his time is pretty close. The Vrod rider failed to comment on his speed!! Sore loser I guess.
