Fried unit near battery....?
Discussion in '3rd & 4th Generation 1990-1997' started by LayinLow, May 11, 2019.
  1. LayinLow
    LayinLow New Member
    What is this unit...and why is it cooked..lol. I've got a vfrness already, and a good rectifier...no voltage spikes recently. Bike does have 65k miles on it and a lot of custom wiring due to me making it a streetfighter. Thanks!
    -pic attached
    if you ride long enough, these starter relays and wire terminals can melt down, and it's NOT uncommon. frequent inspection and periodic cleaning can delay that problem, but sooner or later.........................
    the melting begins on the left upper teminal connection where the green corrosion has started.
  3. LayinLow
    LayinLow New Member
    Would totally explain why periodically my starter button hasn't been working on the first push...lol. Shizer
  4. squirrelman
    sure would :(
  5. LayinLow
    LayinLow New Member
    Is there a go-to brand like Rick's or whatever...or just one of the eBay specials?
  6. squirrelman
    some clever lad in iowa makes them by hand, no other known sources in USA.
  7. LayinLow
    LayinLow New Member
    Sounds pricey...lol...who might that lad be?
  8. NorcalBoy
    Try Caltric, they sell a lot of reproduction parts for moto's and they should have what you are looking for. The solenoid might not be round, might be square, but if you can live with that, you're golden for less than $50.00 for a starter relay and solenoid. They have them for most generations.
  9. LayinLow
    LayinLow New Member
    I think it's just that relay that I need. When I moved the wires in that fried mess, the power would come back on. Where's the solenoid of which you speak? Not the actual starter itself on the front of the bike?
  10. NorcalBoy
    BMW, HD, and Moto Guzzi are the only bikes I know of, with the solenoid integrated into the starter motor. There could be more, but those are the ones I actually know of, lol. I'm guessing your moto is a 4G, merely by the look of the tail in your avatar.
    3rd Gen
    https://www.servicehonda.com/oemparts/a/hon/506ca718f870023420a3fb8c/battery
    4th Gen
    https://www.servicehonda.com/oemparts/a/hon/506cbbedf870023420a421e4/battery
    The entire assembly is still available from Honda. It would be impossible for me to figure out why the fuse holder melted, before it blew the fuse. "Custom" wiring can do do a lot of "custom" things.
  11. LayinLow
    LayinLow New Member
    Looks like Caltric has them on eBay nice n cheap.
  12. NorcalBoy
    It's a very common part, not hard to come by.
  13. LayinLow
    LayinLow New Member
    I think the three other wires came with the Vfrness as a bonus to redo the skinny factory wires to the relay, and I only installed one of them. It's the biggest one in the picture. Perhaps I should have installed them all...lol.
  14. LayinLow
    LayinLow New Member
    I spent about 5+ hours re-wiring things good and solid with a wiring hub. New relay and all new connections on problem areas. Hot damn did it make a difference. I gained nearly 1.5v in standard running voltage on the meter. No more flickering in my Koso bezel either. I have been running slightly dirty power for quite some time apparently!
  15. mello dude
    Romania
    Nice Job!
  16. NorcalBoy
    And that's how shit gets done. Excellent effort.
  17. LayinLow
    LayinLow New Member
    Thanks fellas
